1 - 20 of 26 Posts
CR-Vtakin
your mom
kyb agx
ground controls w integra spring rates
gsr 24mm front sway
gsr 14mm rear sway
energy suspension master kit
itr front strut bar
gsr subframe brace
autopower 4 point rollbar w/ crossbrace
Acura TL-P
Shot of the rear setup on my last CRX
DC Ground controls
KYBs
NRG tie bar
ST rear sway
K Sport LCAs
New build will be similar...but better
The Master Fabricator
I have a factory ITR setup...
I was recommended to go to a KONI/Ground control setup by Chris Travis... He said that the Koni/GC setup is the best alternative to a full race 3000+$ setup like the motons.
If car is strictly AutoX or if you're willing to have a jarring ride, then go with linear springs (not progressive)
I'm not upgrading for the time being, so I don't recall the spring rates he suggested other than the fact that they were very high...
koni spss3s and GCs > everything
now i am running the following on a 91 crx si in sts2
kyb agxs modded for height and travel
qa1 400 lb/inch linear springs 7"
every es bushing known to man
ebay front upper rear upper and rear lower tie bars
crazy top secret alignment
205 50 15 azenis on konig heliums
22mm st rear bar
no front bar
next season i am moving to csp and running the following
spss3s with 600 lb/in gcs
asr 32mm hollow rear bar
no front bar
255-40-13 hoosiers on 13x10s front
225-45-13 hoosiers on 13x8s rear
sawzall as needed
255s come in that profile too?
im just waiting for my new set of 710s to cord next season its time for some massive rubber :) tahts if im not driving someone elses car
wow i was buzzin pretty good last night i thought you had the 225 45 posted as 255 45 haha
gotta pay to play... that tire.. will make alot of cars competitive that couldnt fit/work with 275 hoosier.... i didnt go with a 275 cause no codriver... so i cant get those badboys to heat up quick enough ahah
How many events will a set of those last?
You still haven't listed your setup, BTW. :p
91 CRX Si.. bone stock on 195 14" Azenis.
I run STS2 - and I use the term 'run' loosely. :D
-Des!
then why not run G stock?
shifty my setup isnt important :) haha
and the hoosiers usually dont last every long about 50-60 runs but they are arguably faster than the kumhos
Secrets, secrets, are no fun... :)
50-60 runs is probably good for a couple years of use for me, awesome.
1.8 nawz powa
Heres mine
The list:
kyb agx's
stock 26mm front sway
itr 22mm rear sway
dc front strut bar
ASR subframe brace
peterbilt
i would recomend a rear sway bar next
1 - 20 of 26 Posts
