1 - 20 of 74 Posts
Acura TL-P
These blow off valves are replicas of the Turbo XS BOV (not made by Turbo XS). The only difference is it uses horns on both sides to magnify the soud...as if it wsan't loud enough before. I have personally used this BOV and the genuine Turbo XS and they sound, look and fit as the same. The quality of these pieces are great. It is a great valve for those not wanting to spend the $215 on a Tial and are wanting a budget BOV that will last. I have seen some BOV's similar to this where the horns were paper thin, these are not.
Each BOV will come with the weld on adapters and adjustment washers.
They are $70 shippedfor D-series.org members. Each piece will arrive to you in less than 5 days!
(currently 6 in stock ready to ship)
racist-bigot-sexist-homophob
What's the max psi you've run on these?
Acura TL-P
Me personally, 12psi on a 15G/D16Y7 and 15G/DOHC ZC
I have a friend that runs 22 PSI on his H22 using one.
Hey greg any sound clips?
I should have one soon, I delivered one yesturday. I am helping him with his 1jz/Tacoma project and should be building his charge piping soon so it can get running.
1JZ tacome :shocked:
Acura TL-P
Yes, it'll be a beast. The owner is doig most of the fab work himself with a little help from me and a few other local supporters (Pro Performance and GaragePWR)
A sneak peak...
(I'll probably remove the pic shortly)
A sneak peak...
Dude I hope he's taking LOTS of pics. I def want to see that thing done.
Acura TL-P
Discussion Starter #16
I've got several pics. He's building the whole truck. Right now waiting on the AEM and manifold...the twins are off, going with a single big'un. :TU:
Then I'll be building the charge piping and FMIC setup.
1 - 20 of 74 Posts
