Hey guys, i purchased an autometer mechanical water temperature gauge, and i do not know where to kook it up. It comes with a 1/2 NPT mounting nut that the sensor must be screwed on to. Has anyone hooked one of these up before?
does anyone know what kinda water temp gauge that will fit in 91 crx dx..i mean one that will tap into head where old sensoer is at...thanksreturn it and buy a electric water temp gauge.......
thats a good idea i didnt think about that ..btw.. what brand do you have .. or what size is it/thread ?I have my sending unit in the spot where the bleed screw is for the upper radiator hose.
and go to a local speed shop and ask them for the coolant sending unit from autometer. It has the proper voltage scale (stock sensor to autometer gauge is off by about 10 degrees) and a comes with a bunch of fitting adaptors for whatever threaded opening you want to use.return it and buy a electric water temp gauge.......
