1 - 2 of 2 Posts
okay so right now i have a 94 ej1 that im in the process of converting to manual
ive already done the pedals and clutch master cylnder and my next step tis to complete the conversion with droping the tranny and do wiring etc. my problem is the transmission is out of my 93 ej1 that i had recked and the motor and trans was pushed back quite a bit. when trying to shift thru gears i can only come from third (the gear it was in when recked) and nuetral. granted this was when it was all still in the recked car but should i be worried about the insides of the tranny? or maybe my linkage is bent or should i not worry? is there a way i can test it outside the car to see if it can go thru the gears?
thanks yall
if the linkage is still attatched you should be able to run through the gears with the transmission out of the car.
1 - 2 of 2 Posts
