1 - 7 of 7 Posts
Been wanting to convert my automatic '00 civic ex to a manual. Can anyone help me as in all parts i would need to complete this project?...is it even worth the time n money? Help
93 honda civic sedan
i just did this and finishing up. i had a parts car i took everythink from
u will need manual brake pedal.clutch,clutch cylinder,clutch line,auto to maunal conversion mount,shift linkage,manual tranny,flywheel,manual throttle cable,manaual starter, and i sure there more
can use auto gas pedal i am but u can use a manual one,shifter,master cylinder and arm,slave cylinder, and u will alos need to wire the clutch up and reverse lights. anuthing else im missin? It would be easier and cheaper with manual parts car
Honda Civic
98 Civic LX
You could use the search bar. That was what i was told...
Anyways, the swap was easy.
Here is the list:
Starter for manual
Flywheel for manual
Clutch and pressure plate
Manual Transmission
clutch pedal assembly only
Clutch Master cylinder
Clutch lines
Manual "stiffing/transmission" bracket. (auto one works, one hole wont line up though)
Rear mount (you need the bracket that attaches to the manual transmission, the rubber to the frame is the same)
Transmission side mount
back-up switch
Slave cylinder
shift linkage
shiftier
manual ecu (00 you want the OBD II B) (this is not necessary if you don't mind a check engine light and a flashing drive light) (however the car will not pass a plug-in inspection such as NYS)
if you would like to have your reverse light and neutral lights come on you can follow my wiring forum:
http://www.d-series.org/forums/audio-electronics/167127-auto-manual-swap-extras.html
I think this is a complete list. if you are mechanically inclined it will take about 30 hours with 2 people if this is the first time for you both.
Little advice if you do it yourself, pull the motor out the top. its a tight squeeze and you need to remove all the mounts and the ac, but it comes... eventually...
The manual transmission is about 3 inches shorter and fits in nicely.
1 - 7 of 7 Posts
