1 - 12 of 12 Posts
same as above
Is there anyway to tell just by reading the the serial number or anything if an ecu is from an automatic or manual car?
EX coupe
either way.....it can be chipped to become manual if it isnt...
Reactions: workinprog
Looking to swap over my P28 to manual.
Just wanted make sure I had it right here.
Make a jumper for R18, take out resistor R17?
Correct. I did it in my Si. If you don't do it, you're going to get an intermittent idle that will feel like your IACV is clogged. Removed RP-17 and RP-18 together. I didn't put the jumper on RP18, but some will tell you it's completely necessary. I'm running it on a JDM d15b vtec, and it runs like a charm.
Thanks for the info. Will be doing this tomorrow :TU:
1 - 12 of 12 Posts
