1 - 4 of 4 Posts
I want to know if anyone is running a turbo auto civic and what kind of horsepower numbers are you getting and what is your 1/4 mile time
talk to YakuzaKirby
he had a 94 ex with turbo and automatic, he was running 10psi and not getting traction through 80ish
your going to want to do some research on h/d internals for the tranny there usually good for 200 ish for d series
you will also need a big tranny cooler, turbo auto get very hot very fast
also check into shift kits for honda trannys i know the b and h series have them i dont see why u cant find a d series
aslo see about geting a a/f ratio or a wideband youll need it to tune the ecu for correct fuel
W
I worked on a guys 98 coupe with an auto and a Edelbrock kit. Ran pretty good once I got it straightened out. 6.5-7 psi and you could build it all before you launched. Did pretty good on the street, never took it to the track though. I would still rather have a manual.
1 - 4 of 4 Posts
