1 - 20 of 32 Posts
oh you are friggen kidding me , i spent ages trying to find those when i was putting my engine together and icouldnt find them so had to use oem bolts
Guys over on thezcr have been discussing this problem.
You can run the VW kit without washers, but that throws the torque specs off + who knows what else.
The correct stud is from a DOHC Neon kit. Do NOT order the DOHC Neon kit, you only need a stud from it.
Studs: ATP6.760-1LB
Washers: APW1316N
Nuts: APN12-1
Are the part numbers, you need 10 of each.
EDIT: Race Engineering can get them, special order.
so these are the correct 12mm x 1.25 mm bolts then? or are these 10mm bolts? true dohc zc's have a 12mm bolt the 10mm bolts are from d16a7 i beleive
From what I've read, this is the correct stud. I havn't run it myself, but these are the part numbers I'll be ordering, I'll keep you posted.
Ferio inspired
90' Civic sedan
the ones that TurboZC has on his car are the B16 ones. he had to cut one down and ordered an extra set of washers. worked ok !:beer:
No offense taken as I probably should have been more specific. The studs I posted are from an 89 D16A1 very often confused to be a ZC which of course it is not. Having said that, there are many different ZC engines from different years of Hondas.
I make a bold assumption here that it may be the 88-91 blacktop valve cover bolts on the outside of the cover model that you are talking about. Not once in this thread or the one in the original post did anyone qualify what ZC was being talked about. i.e year or car model. Only one person alluded to the A1 and that the studs were the same. I will also state the person that used those studs was emphatic that the thread was an 11 mm x 1.5 pitch and that he had to use that size tap to clean out the holes in the block.
Here are the quotes:JS
They consist of the ARP stud kit #204-4702 (tapered shank version), a can of Brakleen brake cleaner, an M11 x 1.5 metric tap, a 3/16" socket (for turning the tap), a small wire brush (for cleaning up copper pipes), and some WD-40. Trust me, the correct tap for this block is M11 x 1.5. It took 4 trips and a lot of swearing at the Helms manual (The Helms incorrectly states M11 x 1.25) to get this right.
No, that is not an illusion. One of the head bolts is longer than the others (the one directly behind the water pump). I have no idea why Honda did this, but it created a problem. The ARP head stud kit came with 10 studs of equal length. The kit is actually for a 2.0L VW engine. There is no kit made for the D16A1 or ZC engines, but the VW kit happens to fit perfect...well, almost. Luckily, ARP makes a 1/2" longer version of the studs in the kit. That was perfect! I called them up and they had it on my doorstep in 2 days for $11. The ARP studs are on the left and the stock head bolts are on the right.
I was under the impression that the studs used in the VW kit were too short, but would work without washers. Any part numbers on this 1/2 inch longer stud?
icarusdown​
Maybe it should read like this to resolve some of the ZC delineation issues from which car the motor actually came from.
Since yours an 89 ZC I can't say without you verifying the following. The JDM ZC's were usually a year ahead in the system as compared to what the USDM market got. So is there a possibility that your engine is the 88-91 Civic Blacktop? It would have several differences than the Integra ZC's. ie. valve cover bolt location, different number of cam/crank gear teeth just to name a couple obvious ones. Therefore the difference in the studs. Just trying to be accurate. JS
1989 Integra Blacktop DOHC ZC:
Studs: ATP6.760-1LB (x 10)
Washers: APW1316N (x 10)
Nuts: APN12-1 (x 10)
1989 Integra Blacktop DOHC D16A1:
ARP P/N: 204-4702 (tapered shank version) + 1 special order stud 1/2" longer. (working to get official part #).
The only thing I'd like to point out, is the fact that the 89 Teg is not a ZC. So it should read like this:
strudel said:
icarusdown​
JDM 88-91 Blacktop DOHC ZC:
Minor Threat
That was my question in the previous reply. Was icarusdown's car an 88-91 Civic/CRX ZC or an actual 89 Integra ZC? Or as you called it: JDM 88-91 Blacktop DOHC ZC. That's always where the confusion comes from. No one being very specific about what they have. The Integras did have JDM ZC versions for both the browntop and blacktop engines. The easiest distinction are the valve cover bolts. If they are in the middle it's Integra if on the outside it will either be a 88-91 JDM, EDM or Aussie ZC version. I hope you more or less get the picture. It has always been a grey area and most people misconstrew the USDM Integra as a ZC because they don't know any better and it is DOHC. I hope that made sense. JS
Well that's a pretty definitive answer for me. JDM or EDM 88-91 Blacktop DOHC ZC. That's the same one the boys in Europe have stock in their cars I believe. The Teg ZC's will have 20/40 tooth gears in comparison to your 17/34. That's why parts are different and not quite so interchangeable. So a ZC isn't always the same ZC. Unfortunately most people think they are all the same!
PS. I'll try and give you some answers to your PM in the next few days as I will be off and can sit down and think out the correct reply. I don't have all the answers but maybe part of it. JS
I think the problem is people calling all the DOHC D-series engines ZC, when they're not. The 89 Integra engine ISN'T a ZC, it's a D16A1 I believe, and doesn't drop into an 88-91 CRX/Civic. Please please please, stop calling it a ZC.
Euro cars got a different designation DOHC, I believe possibly got an actual ZC in the Rover cars, not sure how that works out, doubt anyone on this side of the ocean is really going to need to know the finer details about it so I don't really care.
If your engine says ZC on the tag, those are the right studs. The bigger problem now, like you said, is people confusing one engine for another.
D16A1 /= ZC
damn right, its not a zc! you can interchange the parts, but the biggest difference is the motor mounts. they did make a 1g zc that is basically the same as the 86-87 d16a1 though, but im not going into detail.
so anyways, whats the "official" part number for the longer stud??
The one at the top works for JDM DOHC ZC.
1 - 20 of 32 Posts
