1 - 13 of 13 Posts
ARP's lube will only be found @ ARP. But you can use oil, assembly lube, etc etc. I'm going to use Royal Purple assembly lube.
D-Series Destruction Master
<---- slaps forehead.
Good call guys, I didn't realize there was some in the box with the studs. For $95, there damn well should be. :TU:
I've got 2 packets of that stuff, one came with my head studs, the other came with the rod bolts.
i still need to pick up some. i got my parts from people who bought it but never installed it and they neglected to include the lube. bastards. its not very expensive. and u can get arp lube from other places aswell.
<---- slaps his nutsack!.
Good call guys, I didn't realize there was some in the box when I was studding. For $95, there damn well should be an AIDS test and condoms. :TU:
:shocked:
I always just used a quality moly based lube when I ran out of the ARP stuff (2nd, 3rd install :D ) That's basically what the ARP stuff is.
what lube do you guys use for assembling your motor
1 - 13 of 13 Posts
