1 - 20 of 43 Posts
I have heard of several different methods and would like to hear which is the prefered by the people that have actually used them and made power with them.
I have heard installing them by instructions included then heard that people had hg leaks when using this method. Then I heard to install to factory spec and then torque and additional 90 degrees.
I am getting ready to install mine and am curious to the best method. Thanks
1992 Civic Si
I set my torque wrench to like, 10, and then do them all, then do them all again at 10 until they stop moving. Then when they're all snugged up I go straight to 65 ft lbs.
88 ED6
I'm not making power by any means but I do something similar to Sentry; except that I final-torque them twice to make sure they're to spec; this actually over-torques them a tad but shouldn't be anything detrimental.
1992 Civic Si
Of course I torque them twice as well.
When you're putting high torque on stuff like a head, by the time you get to the outside bolts the center ones won't be clamping as much. I go over them until none of them move.
92 Civic Hatch
Torque them in 3 different levels
25lbs-50lbs-65lbs (tq values can differ) just like the instructions. have no probs at 22psi and 300whp
1992 Civic Si
I've never seen any mention of step torquing in instructions in the 2 sets I've had.
Honda recommends two step torquing, and I like it. So I stick to that. I do the same sequence Honda recommends.
I hand thread them all on, until they are snug, then torque them to 25. Then I jump to 80. Its holding 30psi just fine, making over 550.
92 Civic Hatch
racist-bigot-sexist-homophob
95 ex coupe
ive always done 3 steps. im going to try it this way when my new set of arp's get here and see if it holds the hg this time
1988 Honda CRX
88 ED6
:werd: to what everybody says!
Though, just a heads-up; avoid "double torquing" on low-torque fasteners. Doing so may push them past the yield point; stretching them and possibly snapping them.
Discussion Starter #19
who's fault did i say it was?
showed a pic to show what happen to mine after many times of use not to say it was anyones fault
Did it stretch or did it break? That is crazy looking.
92 civic hatch
it stretched it, while torquing them down i went to 35 lbft, and they all felt great
went to 70 lbft, and it was the 5th one i torqued and it felt funny as in it spun quite a bit more than the others and i thought that i had pulled the treads on the block, that was not the case when i pulled the head off again i found that, and a cracked sleeve.
1 - 20 of 43 Posts
