1 - 11 of 11 Posts
arp head stud question
I recently purchased arp head studs for my d16y8. I went to put them on and after I threaded them into the block and put the head on they only stuck out about a 1/4 inch for the nuts to go on. On top of that the two outer ones on the back side of the head, that go into the water jackets, stick out about and inch. The original bolts go in no problem so maybe I got the wrong ones? Or am I doing something wrong?
the ARP's use allen keys to chase them in and out. i just did a set and the two outer rear ones wouldnt go in all the way. keep chasing them all in and all out, that should clean them out.
What is the torque specs for ARP head studs? And it follows the same pattern as the stocks ones right?
R2.....Zap Balls
65 ft lbs. follow the fac sequence
1 - 11 of 11 Posts
