1 - 9 of 9 Posts
will a6 head studs work with a y7 head? just making sure before I buy them.
well, i found the answer...
When using a 88-95 block and 96-00 head, you need 9 88-95 bolts, and ONE 96-00 bolt. Of course the shorter 96-00 head bolt goes in the corner where the vtec solenoid is or would be (passenger rear corner)
When using a 88-95 head and a 96-00 block, you need 9 96-00 bolts, and ONE 88-95 bolt for where the vtec solenoid is/would be.
now the question is, should i try to track down one stud that will work, or just use a factory headbolt with the ARP's?
Lifetime Awesome Member
'89 CRX HF
i would honestly try and get that last bolt. you dont want that one corner being a weak link and getting headlift.
email ARP and see what they can do for you
95 civic ex coupe
the one shorter bolt goes closest to the timing belt on the intake side
1 - 9 of 9 Posts
