1 - 20 of 22 Posts
Im after the part number for a set ARP head bolts to suit a D16A6. Nobody here in NZ stocks them for the D16A6, so I need a part number for them to work off.
Anybody know what it is?
stock sedan
use the arp headstuds for a z6 for a a6
ARP part #208-4301
Just while Im here too, Ive seem to misplaced these parts (circled in red). Do I really need them?
Oh ok, that's what I thought. That's what I used them for when I pulled my head, and I always wondered if they served some other purpose I wasn't aware of.
you sure there not in the head? They usually stay in place unless you physically remove them.
They were in the head, but I removed them and put them in a ziplock bag along with everything else. But they have disapeared somewhere. Lucky I have a couple spare trannys lying around that I could take the dowel pins from.
Would it be the end of the world if they weren't installed? Or just annoying to install?
I can't read...
you risk not having the head and block line up properly. that doesn't sound good to me.
Yeah, that's what I was asking. That tenth of a mm you couldn't tell with the naked eye would make that much of a difference? I mean, you could tell if the head was lined up with the block by hand, but you're right, it wouldn't be perfect.
iv not used them in 2 motors and they have never had a problem they help when installing the head so the headgasket dosent shift... but as far as locating it the head bolts do that job for u
1 - 20 of 22 Posts
