Two men shy of a group
99 civic sedan ex
Ok so forgive me if this is in the wrong forum but I thought this best suited it. I am about ready to install my turbo and I need to make my oil drain setup, I can either try my hand at learning to arc weld aluminum with a 4043 rod or I can pay someone to do it which would you guys do? I like learning new thing and doing things myself but I know nothing about arc welding aluminum, I can weld all postions verticle up or down, overhead and all that with 6010 or 7018 and back 6 years or so I was ok with tig welding aluminum. Im not new to welding but I didnt even know you could arc weld aluminum until I thought about looking it up, the welds look like they are pretty cold in the videos I watched even though they are running high amps, think an -An fitting would be alright even without proper weld tie in or should I just pay someone?
I dont have a tig machine but I have plenty of old miller and hobart arc welders at work and also a victor torch, think torch welding it might be easier?Im just looking for some insight, I would have to buy the aluminum 4043 rod but I can take my oilpan to work and weld It up.
99 civic sedan ex
i definitely want to try it, main things im worried about is it not fusing the fitting to the oilpan good enough and also messing up the fitting or oilpan
99 civic sedan ex
im sure you can but i dont have a mig at home or work, we use arc at work. i have a cheap harbor freight mig but its flux cored and has no bottle hookups
