1 - 12 of 12 Posts
D
I got a ZC tranny, which equates to good 1-5 but a DX spec FD.
Other than the USDM Si final drive, are there any other things that make for shorter combinations? Like using another tranny's 3rd as your 4th, or whatever?
Also, this motor will probably be cammed and turbo'd. WHEN it blows up, I am going SOHC. Is the USDM Civic RTi D16A6 the only SOHC block I can use for my ZC tranny? Or are there other, newer ones, that have a place for an Int shaft?
D
It would go into the DOHC ZC case. Mid-shaft > unequal length axles. Transex, is what I posted the shortest possible?
Now that this ZC may need a HG after just fixing the IM gasket, I'm not fixing it,(I heard all these rumors about these ZC's anyway) but the trans will live on to serve an H22A mated with Bisimoto H/F to D deries tranny conversion kit.
The custom ratio ZC trans is cost effective, and will have better ratios than a H22A tranny.
why in the world would you want to run a weak d-series tranny with a torquey h22a?
i could see like a h2b, but h2d?
if you're going to do all that you might as well get a h2b adapter and run a b16 tranny, there's several more options for b-series. Well, d-series has more options of gears, but the b16 tranny is the perfect tranny. and jdm OEM 4.785 final drives
D
Bisi Eihzoria uses D series trannies on his 350 HP + F series motors. F and H are compatible. My motor would be bolt-ons+cams. Turbo VTEC D's put out more HP/TQ at the wheels, on D series trannies, don't they?
Besides, I have the ZC tranny. With it's ratios and that 4.9 FD, who needs a B tranny anyways. Beside, most cable B16 tranny grind into 2 and 3rd. The ZC tranny doesn't, is cost efficient, and just like B16, has a midshaft.
I really wanted to turbo this ZC I have, but it had to fuck up AGAIN! After only driving on it 3 days.
da, with boost run the ZC tranny with a CRX DX/Si 5th.........
4.9 FD will prove to be useless and you'll be shifting too much.......4.25 and boost would be too much with the close ZC ratios
FYI Bisi runs a 4.40 FD with 27" tall slicks
SLO SOHC said:
does anyone know if I could us the zc gearing and keep my final drive in a y8 trans?
you can swap in 3rd and 4th, 4th needing grinding to fit. Then choose a 5th, I prefer the .771 for the D15 I'm running.
D
Is the 4.4 Aftermarket or one of the hard to get D series 2G Teg FD's?
What do you suggest with either motor? Since I refilled tank, I've had 3 more days without the ZC overheating, so, I will check the radiator, and if it's still full, then I can pin the rough running to the ECU codes I have (10,16), and determine the motor fit to turbo.
But if not, then H22A is on it's way. What is your choice of gears for that motor, with D series gears? Also, you say, if ZC turbo, use the ZC 1-4's and DX/Si 5th, but no FD is mentioned. I'd imagine that the ZC's DX final drive is unsuitable for any kind of speed.
Last note, I don't make compromises, so I don't care if I'm crusing in 5th at 5500-6000 at 80 MPH. Likewise, I'm willing to run Crespo stage 5 cams daily in the ZC. If it truly is better to have the shortest gears possible, please tell me. I don't think a turbo ZC, nor a bolt on H22 would run out of gear.
Just looking for final confirmation before I go stockpile part/make WTB threads at CSR/CSS.
Thanks.
4.4 is a Houseman piece, about $1500
ZC gearbox, DX FD, the close ratio will make up for the FD.
I've run out of gear with my D15.....it is not that hard..........
1 - 12 of 12 Posts
