1 - 10 of 10 Posts
just wondering if anyone with FJT custom length i beams had a tight clearance on their rod bearings?
mine are a tad tight.
how can you get a smaller bearing? is it ok to mix and match OEM with ACL (i would guess no because they are different design)
i had problems getting the rod caps off so i think my readings might be a bit out.
just wondering if anyone else had a similar reading. (couldnt imagine my crank growing... lol)
88 ED6
Yes, you can mix and match bearings as long as each of them are in spec. The ACL's are suppose to be similar to "Green" sized bearings.
The dealership should have what you're looking for.
nonvtak ftw
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586
i had the crank micro polished.
just wondering if anyone who used the rods had the same experience w/ the rods and the supplied acl's.
from what i remember min clearance was 0.0008-0.0015. and my green plastigage kit's most specific measurement was exactly .001. and when i checked the width of the plastic strip (after torquing down of course) it was slightly wider than the widest strip on my plastigage reference piece. so, its tighter than 0.001.
so my guess is somewhere around .0008... i need better tools to know for sure.
1 - 10 of 10 Posts
