mods are intake ported z6 header 2 1/4 exhaust in a 95 civic ex obd1... doesnt matter if its crome or uberdata... thanks
nah.. i got the hatchie thats boosted... this is my daily driver.. i just thought i could optimize the power instead of running on stock mapsretard the stock timing maps with 3 degrees.
add 10% fuel to the fuel maps, which doesn't matter so much since you're running in closed loop, so the ECU would correct itself ..
if you go boost, then that's a different story
yea... i had a stock muffler on a 2 1/4 pipe.. i unbolted the muffler just to see what would happen... its like a totally different car.. its soo much faster even my friend with the turbo del sol said he couldnt pull as hard lol:alky:just run OEM. no need to retard. that .8 difference in CR is not even 10hp
probably a good idea to run premium, too
its actually a whole point its 10.24:1 the head is shaved 40 and im using the y8 2 layer hg stock compression is 9.14:1... lol stock 99-00 si b16 comp ratio is 10.28:1 loljust run OEM. no need to retard. that .8 difference in CR is not even 10hp
