My CRX climate control isn't going to cut it for much longer so I am looking to swap in something more durable and functional. I know it owuld easier to grab another one and swap it in but they always break, and it's always teh same switches that break too. So what is a good climate control that isn't too difficult to swap in, any ideas?
I have the cable climate controls out of a EF Civic hatchback. Compared to my friend's CRX Si, it was different than what he had. It was easy enough to install since my car had no climate controls/HVAC stuffs to begin with.
the fan plug does sorta but you will get a dead spot on the fan speed. the Accord has 5 settings, while the CRX has 4.
i fixed this by wiring the Accord plug into the CRX one. then wired 2 of the lowest fan speeds together so there is always a speed in the "on" position.
but the door control has to be modifed. either cut and solder the accord plug into the CRX dash, or make a conversion harness like i did. i might roll around and do the write up on this as i was way too lazy last time:beer:
the knobs in my 90 Accord are fine,. and the climate control in my 88 STD(the ones in my 88 CRXs broke). I'm planning on doing a EG climate control swap on the STD, i like the slide-switches vs. the knobs.
it gives you a good start, but the wiring charts arent always dead on.
use the correct factory manual for the year you are working on. though i did giev those guys a bad ass way to make the Accord temp mix work with the CRX one
