1 - 7 of 7 Posts
If its a subaru flanged VF34 then most likely not. They arn't as popular as more conventional turbos because of the non-standard bolt pattern.
You might get lucky and stumble across a few oddball threads here and there but it doesn't seem to be as easy as finding info on a more conventional setup.
MuthaFuckaUppa
I was running a TD04L from a WRX, was planning on up grading to a VF34 or something, but the cost of a used one was not to my liking.
Well they are a bit of a middle road on a 2.5 and make about 280/270 on a 2.0 with a touch of lag. I predict it will be fun on a 1.5. :)
So your saying its not going to spin up all that fast. And that It will work well at the higher RPMs. I was hoping for a setup which would make boost in the low RPMs.
Not having access to a Map for this Turbo makes doing the number crunching hard.
Maybe I just need to look harder for that map.
1 - 7 of 7 Posts
