1 - 7 of 7 Posts
R
hey guys, a buddy is swapping out his d15 (91 std hatch) to a zc motor,
he got the motor, si tranny, i think ecu and he is getting someone to do the wiring, anyway i was wondering if there were any good writeup or how to's anything really would help for swapping the motors. does it bolt in directly like the dseries did? does he need to upgrade axles?
im pretty sure he has what he needs, but i would like maybe some pictures or how to that someone has documented when they did theirs
thanks, btw i search some before posting
if someone else is doing the wiring then your set. . .. take old motor out
put new motor in. . . . . DONe
zc is a bolt in
havent you seen my MOVIES?
CR-X
D-Series Destruction Master
G1tegZC said:
For best results use a 88-89 (US) teg ECU or a PM7 (JDM)
Not saying your si ecu wont work.....because it will.......
But those two ecu's run the motor the best....
what about emissions testing, wouldn't the SI be best, since it wont burn as much fuel?
R
thanks for the help guys im sure it will all go good, i guess he is gonna have someone do it, so we will just be dropping it in
1 - 7 of 7 Posts
