wow...you've got a ton of reading to do...How much boost are you running? Get a real tuning program and get it tuned right...
my set up is d16y7 block; y8 intake;rc550 injectors;aem FPR; t3/t4;;2 1/2in exhaust;;safc;;blow off value ;external waste gate;;ngk7 plugs
my problem is i constantly breaking the rings on the 1 cylinder ;;;i bought a set of vitara pistons and rings i am setting back up the car but just thought i would ask to c if anyone having this problem or anyone have a solution ;;;the cylinder wall is fine no visible problems
Check out PGMFI.org, there are links there to tons of basemaps. You can probably find one for a car setup similarly to yours.i bought myself a greedy ultimate e-manage but from reading here i am getting to understand that the chip ecu works better (not making that an issue) what i am wondering is there anyone here that can hook me up with a chip ecu that have a basic setting that would work for my setup i also understand that since my ecu is OBD2 i need to get a conversation harness to OBD 1 so maybe someone can hook me up send me a PM or Email lets talk business or point me in the right direction
