1 - 10 of 10 Posts
C
can some one please tell me what car the dohc zc engine came in originally? i need the year too. i cant buy parts at the part store with out it.
hope this helps some
Parts Interchange List
Engine Mounts:-----1988-91 CRX/Civic
Timing Belt:-----1988 Prelude 2.0
AC Compressor / Parts:-----1989-91 CRX/Civic
Throttle Body:-----1988-91 CRX/Civic
TPS:-----1988-91 CRX/Civic
ECU:-----1989-91 CRX/Civic Si, 88-89 Integra 5-spd, 89-91 ZC
Intake:-----1988-91 CRX/Civic
Headers/Exhaust Manifold-----88-91 CRX can be used port will not be perfect---Ideal is DC 86-89 Integra Top with 88-91 CRX downpipe---(I use port matched GUDE 4-1 Header)
Plug Wires:-----1986-89 Integra
Spark plugs:-----1986-89 Integra or 1988-91 CRX/Civic----- NGK BCPR6E-11
Distributor Cap:-----1988-91 CRX/Civic 1988 Integra
Distributor Rotor:-----1988-91 CRX/Civic 1988 Integra
Head Gasket:-----1988 Prelude
Intake Gasket:-----1988 Integra
Exhaust Gasket:-----1988 Integra
Water Pump:-----1989-91 CRX
Oil Filter:-----1988-89 Integra-----Fram PH3539A
Oil Pan Gasket:-----1988-91 CRX/Civic or 1986-89 Integra
Flywheel from 1989-91 CRX Si may be used
Transmissions:
4 speed 88-91
5 speed DX 88-91
5 speed Si 88-91
5 speed ZC 88-91
ZC Pressure Plate:-----1989 Civic DX
ZC Clutch Disk:-----1989 Civic DX
C
im not sure thats why im tryin to find out as much as i can about the motor so i can max out the hp. so all facts about this motor that anybody knows would help me alot!!!
1 - 10 of 10 Posts
