1 - 2 of 2 Posts
Hi! im building a D15/D16 head with Itbs, and i will install a Skunk2 Stage 2, indeed it's installed already just im looking for degree it, tried to talk with skunk2, they dont have any more info than just valve clearance, lift and duration, indeed i was trying to measure duration and i think i measured it right and it's more than just 225º in the exhaust side..well if anyone have more info about this camshaft, definitely if i know it, i get 59300 since i used in other builds and works good.
Any help will be appreciate it a lot.
Thanks!
Yeah, pretty dumb on their part but I guess they can get away with it since most of their buyers just don't know better. Every aftermarket cam should come with a cam card to verify the specs and also to make it sure your valves don't hit... There are so many more vendors out there that can get a you a good cam and can stand behind their specs. I have heard good things about Bad Guys and Web cams. Great customer support.
1 - 2 of 2 Posts
