1 - 17 of 17 Posts
Honda
Hello people. Could someone give me advice fuel rates and degrees of ignition for an anti lag aggressive . Or stable. I've tried and Fuel -120.00 -45.00 Retard but nothing new. No flames..... :willy_nilly:
Leave your suggestions and we will be able to be. I have seen the setting that much already see the forum and nothing happens even a small flame
I count on your help. A long time I follow the forum.
if you have any catalytic converters on the car they'll stop the flames
same with any chambered mufflers
also this is dumb
Reactions: slo_eg8
if you want flames, buy a flame thrower kit. stop torturing your engine for nothing
Reactions: transzex
same
expectations vs reality
Reactions: slo_eg8
97 honda coupe
raise the rpm your doing it at and change your rpm re-engage point to 200-500 less than cutoff, cut spark only not fuel.
I usually ran my timing around 24 degrees and 140 fuel, however like you have found, i could also not get a n/a motor to truly anti-lag. Im assuming this is because of the lack of oxygen in the exhaust that the turbo provides even when the fuel cutout engages.
Get a Bee R rev limiter controller
Honda
Discussion Starter · #11 ·
Good not have catalyst. This hotline.
It's just to make from time to time. So it will not do great harm to the engine.
Ok I will testing the configs that the colleague said, then say something.
The announcement of this douritos top.ahahahahah
Honda
Discussion Starter · #12 ·
Cervan not working...The same...Working but not flames...You what see photo of my configs?
Reagrds to all
my bike would shoot flames bouncing off the rev limiter, but it was also carburetted
Add more fuel. And since you are retarding spark, or maybe even turning off the spark if you use igniton cut, then you will need a really HOT exhaust to light off the fuel.
If you are doing it on a cold engine, it wont work.
97 honda coupe
he might be able to make it work by putting a piece of tungsten or magnesium in the exhaust right off of the header igniting the fuel.
1 - 17 of 17 Posts
