1 - 20 of 30 Posts
So I was looking around on the net and I saw a different solution to get oil to the turbo. They call this the "oil sandwich"
It will look similar to the picture posted below:
What do you guys think of this idea? There are ports for the oil feed and return.
Actually its a very common way to feed your turbo. I like it because you can also have your oil pressure sender there without worrying about something breaking or making a firewall mount. And you can have your oil temp sender there too.
But like DreaMer said - dont try to run your return into it. ;)
racist-bigot-sexist-homophob
Fuck all that shit, I use jedi mind power.
i run one also. i could never find a fitting that fit into my block with the right threads and not leaking. its a great investment.
lol
sandwich plate adaptors can be had for real cheap on ebay. Its a manditory part when building a turbo engine for me. fresh clean oil into your turbo and extra ports for oil pressure gauge.
I think this needs to be answered again...does the "dirty" oil flow through the center and out the sides "clean"? If so, the sandwich would flow clean oil to all your devices.
pretty sure the port on the block is filtered oil. well directly filtered...it all gets filtered.
a sandwich adapter isnt a bad idea
cheap ones are.
from the pic posted the holes from the adapter are unfiltered
unfiltered oil comes from the pump to the outer ring of the sandy, goes through the filter then out the threaded connector
high quality ones have plumbing inside them (some even have a thermostat) that brings filtered oil from the after the fitting to your lines
just use the stock sender. it costs you one male to female bspt fitting.
1 - 20 of 30 Posts
