1 - 4 of 4 Posts
91 Hatch rally car
What do I do with the speedo cable if I don't want to run a speedo?
The race dash has a GPS speedo, so we don't need to use the old school cable drive. I want to remove the cable from the D15B2 cable trans, but don't want to cause any problems, like all the trans oil splashing out or something in the trans self-destructing.
So, what do we do with the cable?
Pull out VSS cable locking assembly from trans, install plug.
Pull cable, cap nipple with cap.
Pull cable vss cable locking assy out of trans, replace with hydro vss pulse generator.
It does nothing except turn from teeth mounted to the differential. Nothing bad happens if its removed completely.
1 - 4 of 4 Posts
