1 - 18 of 18 Posts
2000 Honda Civic EX
Hello!
So I kinda migrated over from Hondacivicforum.com.
theyre not so kind. but from what Ive been reading this place is much more helpful, so Ill give it a try. =)
I have a Pacesetter Highflow Cat on my 2000 Civic EX. and it is smelly...
rotten-eggs-sulfur smell and what-not. but only when ran hard.
I also have some Venom high flow Fuel injectors installed. 10% above stock CC rating.
I figured I was just running rich with the slightly bigger fuel injectors. so i installed the stock ones to see if that was the case, but it still made the cat smelly. Ive read elsewhere that some cats just smell..well...just cause!
any ideas?
peterbilt
use the stock one?
i thought this thread was bout lisa kudrow(sp)
peterbilt
i run catless(resonated test pipe) and it just smells like exhaust....no smell complaints from either the stocker or the test pipe....maybe its just THAT cat that smells?
2000 Honda Civic EX
thats what im thinking, and trying to see if anyone else had the same problem or not.
resonated test pipe works ok? all the other threads kinda contradict eachother.
resonated test pipe works ok? all the other threads kinda contradict eachother.[/QUOTE]
yeah, im just runnin a "custom" intake, header, resonated test pipe, and 2.25" catback with twinloop muffler. sounds great. didnt notice any differance switching from stock cat to the test pipe other than a little sound differance.(exhaust is obviously a LITTLE louder, but much deeper and has a "punch" to it)
huh?
If it only smells when ran hard, then your toasting your cat...chances are its the injectors that did it...
huh?
Mroooooowwwwwww.....burn kitty!
1 - 18 of 18 Posts
