1 - 4 of 4 Posts
I'm about to do re-ring my D16 and was thinking while i got the pan off i would go ahead and change the oil pump and i've read alot of post here about oil pumps but none that i have found have said whether or not you have to prime the oil pump with petroleum jelly or something like that. So is it necessary to prime the oil pump with jelly or just install it disable the fuel supply and crank the car over until you see some oil in valve train area?
thanks,
kif
1 - 4 of 4 Posts
