1 - 20 of 23 Posts
Alright well i just got back from my friends house and on the way home i was driving slow and easy. I dropped it down into 2nd gear and give it some gas because i was falling behind traffic. All i hear is a snap and my battery light comes on. This happened 2 days ago but that belt is completely sredded.
Am I doing something wrong when installing? should they be loose because we put them on with maybe 3/4 belt deflection.
You complaining because a old shredded belt snapped?
They don't last forever, replace every 3-5 years.
91 CRX Si
at least it's an easy fix.
no we replaced it with another new belt from pepboys and now 2 out of the 5 ribs are shredded off the belt.
When i did my alt belt i just did it by hand and checked the reflection. it wasn't exactly where it was suppose to be but i didn't worry about changing it. it's tight enough. make sure the belt sits flat and don't rub the edges on the alt maybe? make the the teeth and belt fit exactly.
hmmm...maybe im just overtighting it because i was going hard with the wrench to tighten it. well luckly i just bought the pepboys belt so im gonna go get a new one
well we put a new belt on from pepboys. then that snapped two ribs and flew onto the highway (recovered) then used another 3 rib belt i had at home. put that on last night and on the way home tonight as soon as i really let the car open it the belt just snapped.
i would personally just tighten it by hand. and check to see how it moves when running. only thing is you might need to tighten it later on because the belt will stretch over time. i tightened mine just by hand and haven't had to tighten it since though. If it does seem to make any noise when running it could be too loose or too tight. mine was loose at first and had a high pitch whine. so i tightened it up. good luck though let us know how it goes
your grammer owned you in your first post. A comma does wonders.
Did you clean out the grooves on the pulleys?
Crank walk?
You should only have 3/8" deflection @ 22 lbs of force on a used belt, 1/4" on a new belt (less than 5 minutes run time)
i noticed the engine bay would squeak at lower rpm.
lol thanks transzex. yea im a little frusturated right now. its a brand new alternator. i hope to god its not crankwalk. ill check the deflection again with another new belt.
you sure you dont have a 3 rib on the allty, and 4 rib on crank? or vise versa?
as in the pulleys ribs.
after 4 hours of trying everything we found the problem. since my mounts are dying the viberation has seemed to crack the upper bolt that holds the alternator flush with the bracket. so after 7 dollars for a bolt from honda the car is back up and running with a new bolt and belt. now i just have to figure out how to get my p/s belt back on lol.
d-series Member
lol im restraining myself i really am.... ;D
fuck ps...dont need it at all !!
1 - 20 of 23 Posts
