civic coupe
ive got a b20 swapped sedan. My alternator is bad, what ones will all work?
any b-series not sure about d-series, i think hey are different
d-series will work on a b-series...i have one on my b20...you have to loosen the 14mm bolts that hold the TOP alternator bracked to the block, place the alternator in its place, put the 12mm adjuster nut thru the alternator THEN tighten the 14mm bolts and your done :)
