1 - 6 of 6 Posts
1988 Honda CRX Si
Motor: d16z6
Bored:75.5mm
Rods: Golden eagles stamped with 5394.AHO with arp 2000 bolts
What area of the rod hits the block that makes it require notching? What do i need to measure on the rod to know if i need to notch the block or not? I'm searching as i'm waiting for a response to this post.
Thanks in advanced!
Mondo
i took mine to the machine shop to get it done, but he told me that he would assemble the block and see where it is hitting, while marking it at the same time. then follow up with the dremel and grind it so the rods will clear the block
1988 Honda CRX Si
im kinda on this self accomplishment mode so i went out and bought a dremel which has many uses and the appropriate bit for cutting! lol. I one side of the block notched. thanks! Its obvious which cylinder was the first one i hit with the dremel lol. i need to go back and try to smoothen them out a bit lol.
4G93 Turbo
1 - 6 of 6 Posts
