21 - 40 of 41 Posts
R2.....Zap Balls
94 Ex coupe
Discussion Starter #21 (Edited)
added some pics and links to the post. Going to post up some how to's on getting the dash apart with pics for people on diff models
FAMILY MEMBER #316
97civic123 said:
anyone has a step by step on installing an alarm into an ek?
this is a sticky..try not to post here. create a new thread and youll get a lot of responses. if you need a step by step, i can tell you but i dont have any pictures.
I asked this in the noob forum but got no answers:
In a remote start system, how long the alarm will try to crank the vehicle? how does it know the engine is already running and stop the starter??
R2.....Zap Balls
94 Ex coupe
Discussion Starter #26
it will try 2 or 3 times before it figures out it's not going to start. I just pulses the starter to turn it over. The remote start is hooked into a rpm feed, that lets it know when it's running and it also keeps someone from getting in and blowing your motor or stealing the car. Once it hits a certain rpm, it kills it to keep someone from just jumping in and over revving or taking off in it.
wow, cool; rep for you, dude. Thanks.
Another question:
I've seen some alarms can put a limit to the revolutions of the engine, those systems turn the car off or really limitate the revolutions??
If they put a limit to the engine's RPM, how they do that?? I don't see any connection between the alarm and any component of the vehicle to cause that feature.
1993 civicEX
just reading through this forum dude good post i just wanted to add that anything besides DEI systems are total shit and by no means do i wanna take thunder from you vtecduck but if anyone has questions on any of the DEI systems or has questions about wiring i can help
1993 civicEX
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 1997 / Remote Start
12volts white (40A) + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow + ignition harness
Second Accessory white/black + ignition harness
Keysense blue/white to blue/red - ignition harness
Power Lock green/white - driver kick, blue plug
Notes: Also found in the green factory alarm plug located behind the radio.
Power Unlock green/orange - driver kick, blue plug
Use blue/yellow to unlock the driver door only.
Lock Motor white/red 5wi driver kick, door harness
Unlock Motor blue/red to yellow/red 5wi pwr door lock ctrl unit in driv door
Parking Lights+ red/black + driver kick, fuse box
Notes: Male blade terminal at fuse box. Also at the back of the dimmer switch.
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) green/red + steering column
Turn Signal(R) green/yellow + steering column
Reverse Light green/black + driver kick, harness to rear
Door Trigger lt. green/red - factory alarm plug
Can also be found in a light green plug above the fuse box or bottom of driver kick, harness to rear.
Dome Supervision lt. green/black - driv A pillar or factory alarm plug
Trunk/Hatch Pin blue/black - driver kick, harness to rear
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue ac test tachometer connector
Notes: Driver side fire wall under hood.
Wait to start N/A
Brake Wire green/white + brake pedal switch
Parking Brake red/green - parking brake switch
Horn Trigger blue to gray - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
if there are any other wiring questions let me know i searched through the years and nothing seems to change but just remember to meeter all your wire you dont want to fry anything
1989 Civic DX
I figure this is the best place to ask this.. which company has the most reliable reputation when it comes to security? My biggest concern is the quality of the product and the transmitter to the pager/remote. I'm not just looking to deter and disable, but I'd also like to know what is going on so I can at least catch a glimpse of the wanabe thieves.
My car has been broken into twice this week, in my drive way. The broken street light doesn't help. On top of that, five reports of stolen vehicles just last night in my immediate area.
E
Need Help. I have a Viper 476v alarm put in my car so i have keyless entry and remote start. My alarm keeps going off every 45min for no reason and now my car won't start remotely. What do I need to do??? I bought the car 2 years ago and had no manual.
why does my alarm keep going off??
So if i change the battery in my remote will that fix it?
the remote works fine i still can lock and unlock my doors. When locking my usually beeps once and now it has this extra beep what does this mean
21 - 40 of 41 Posts
