1 - 4 of 4 Posts
help i wanna ask
if i put a n2o to my engine?
and the spec are
vtec head p08-3 (with pnp n triangle valve job)
stok short block zc engine (with honda ferio stok piston & the estimate comp are 9,5
4-1 ext header
last
wet system n2o (with 35hp spuyer)
what maintainance should i do every time i goes to car service?or every 1year?
what internal parts should i check every times i service?
i would just make sure your engine is running right. do a compresion test get some new spark plugs( maybe colder plugs?). you could probably get away with even a 50hp jet since your wanting to use a wet kit
thx bro,
but i use street act clutch n only can reduce 200hp over 200 the clutch wont works optimal
what spark plug should i choose?
could i use NGK irriway 8???
still ask the problem what kind maintainance?
1 - 4 of 4 Posts
