1 - 12 of 12 Posts
its basically just a light show if its not a wideband...they can only read a certain number properly but i cant remember what that is...
its completely worthless for tuning...but can be handy if you have a sudden fuel issue. These guages only really measure the extremes of your AFR. so if it goes red...pull over and check everything.
Normal O2 sensor "narrowband" give a 0-1 volt signal. At .5 volt your a/f ratio normaly are at 14.7(where the engine make less emission and still have "good" power for crusing)When you are at a constant speed, the signal oscillate between .5(normaly from .3-.4V to .6-.7V) and when you are at WOT the signal are completely useless because the ecu normaly aim a 13-13.5:1 a/f so the signal are always in the .6-.7-.8Volt(WOT)... If you buy a kit-gauge that only read narrowband you will only know if you run lean or rich but will not know how lean or how rich!
A wideband normaly give a signal between 0-5 volt(normaly between 10:1 and 20:1 a/f ratio) and give the EXACT a/f ratio at ALL time!
I recommand you to buy a wideband....
O
that will only work during full throttle operations,. the rest of the time it will be 100% wrong. if you want a tuning one then get the new aem one witht he wideband O2 and gauge together for about $299 most places.
Lifetime Awesome Member
lol, just cruising they will bounce from extreme lean to extreme rich the whole time. red wont mean anything
B
i have an autometer A/F ratio gauge and i agree with the other guys, it's crap! i'm gonna save and do it right and probably go with the aem wideband.
1 - 12 of 12 Posts
