1 - 7 of 7 Posts
I have air coming out from the breather filter of my valve cover, as far as I knew this was just supposed to vent air. What does that mean? Engine is sucking past the rings, head is cracked?
just do the ole oil cap trick, pull oil cap off..if u can feel the air still around 10inches above it...very possible you are gettin good blowby.
or the piece of paper over the breather port, if it don't hold it in place you got blowby. but its not necessarly a problem yet though.
Actually I typed that wrong. The motor is sucking air in from the breather filter rather than pushing it out.
1 - 7 of 7 Posts
