I haven't seen anything about this posted, so here it is if anyone is curious about it like I was. This isn't a DIY, it just tells you the recommended aiming for the lights.The info is from PIAA's website.
FOG/FOUL
WEATHER
LIGHTS
Traditional fog lights are usually mounted under the front bumper about 10-24 inches from the ground. There are two important issues to address when installing fog lights, the first is to minimize the amount of return glare into the driver's eyes, and the other is to minimize glare into oncoming driver's eyes. Both must be accomplished while putting as much light as possible on the road.
These fog/foul weather light aiming instructions are suggestions taken from common practice and the S.A.E. standard J583. Some modifications to these instructions may be necessary to minimize glare.
Visual aim is made with the top of the beam 4 inches below the lamp center at 25 feet with the lamp facing straight forward. (See below.)
FOG/FOUL
WEATHER
LIGHTS
