1 - 20 of 33 Posts
Does anyone have videos of their d's idling with any type of aftermarket cam. i would like to hear the difference. so if anyone has anything they can post please help me out. Thanks in advance.
when you first start the engine, after a build you want to start from idle rpm range 0-1200 or so and balance that out to 13.5 ? then work you're way up the rpm band balancing the a/f ratio to 13.1 ?
this is for my engine build which is identical to marcin, d16z6 in a ef, crower stg3,itb's, etc etc
thanks, i'm new to tunning concepts
this is a good article about break in/start up
http://importbuilders.com/breakinarticle.htm
this is another article about break in/start up
http://laskeyracing.com/shop/breakin.htm
as well as this has some good pointers about tuning, although there is some not great info about vtec in there.
http://importbuilders.com/tuningacar.htm
advertised duration: Int=280.5 / Ex=300.6
duration @ .050: Int= 230.6 / Ex= 218.9
lobe seperation: 111.6
gross lift: 417/432
Non-Vtec. Running sidedraught carbs. Not yet in the car though, awaiting forged internals. Gonna spray 150 shot DP.
Who needs Vtec when you can lope like crazy ? :)
gross lift: 417/432
hehe. that should be interesting. =)
just curious which cam that is that you plan on using?
thanks
m.
No idea, it's a custom grind. The head it once resided in was once ported at DH-Racing though.
I got it off Lohatch through the D-series classifieds. First I'm gonna get my carbs running properly though, they're only a set of PHH40's so until I can afford to go built I'll be running a Delta 282 or so on virtually stock compression, but with the ported head nonetheless. Should be interesting as well.
1995 Honda CIvic LX
Car sounds good tuna.
95 civic ex coupe
D-series Janitor
Front Engine Dragste
238* 225* @.050
.442/.468
What are the non-vtec lobes? That thing purrs.
Does anyone have a clip of a delta cam? There seems to be a lot of people with them but no clips.
Also, what is the deal with intake bias on 99% of honda cams?
Of the honda head I flowed and the sheets I have seen on the internet, the stock intake is roughly 50-60cfm better than the exhaust.
IMO, intake bias cams are usually hype.
1 - 20 of 33 Posts
