1 - 7 of 7 Posts
sorry about my english
after engine rebuilding and at first start car dies
i start the engine ands when i press the throttle to 1.5 rpm the speedometer moves to 120 km and then 20 km all of this at neutral when i release the throttle the car turns off
any sugesstion
also
i tried to check if there is any thrown codes but the check engine light don't blink i thought it is bad ecu so i have tried the ecu on other honda with d16z6 engine car started good but the car i 've tried the ecu at was auto trany and my car manual do the ecu have to throw a code on this car because of the auto trany (my ecu was auto and converted to manual)
also i need to know something else i found my trany ground wire not tightened well can this make my car not to start
what to do else no codes thrown check engine light always on no blinking ????????
fuel pump ok
new spark plugs
timing ok
why when i put the key in on position beep sound happens
why the check engine light always on i cant check for any codes
there was no code the check engine light is constant no blinking code zero
and problem was fixed
here is the page fixed my problem
1 - 7 of 7 Posts
