it should be set to the voltage of the old tpshow do i reset the tps ??
how do i do that ??it should be set to the voltage of the old tps
Multimeter and a haynes bookhow do i do that ??
x's 2Did you reset the TPS(Throttle Position Sensor)?
Might have a leaky IACV, got a vac line loose somewhere.
Also might have to adjust the idle screw if it has one. I'de serisouly check the TPS first though.
yeah you might have a leak did you scrape and clean off the old gasket material from the IM and TB?shouldn't need to touch the TPS, I'm betting the gasket......
That's what I was thinking when I saw the title of the thread.shouldn't need to touch the TPS, I'm betting the gasket......
