1 - 1 of 1 Posts
I just wanted to get your guys opinion on what I should do. Here's a pic of my column
As you can see its tilted like 20 degrees clockwise. This includes the tubing behind the wheel. There's also a problem when rotating the wheel, something is scraping making it hard to turn. So I went to remove the wheel. Pulled airbag and 19mm center nut. And when I rotate the wheel the 19mm bolt doesn't stay straight. It wobbles, pretty sure its bent. Do I have to replace the whole column? Thanks, ill try to borrow a camera for video because its hard to explain.
1 - 1 of 1 Posts
