1 - 10 of 10 Posts
i am startin to look at the option to turbo my civic,but there's nowt on the market for my engine. its a d16v1 which i understand is exactly the same setup as the d17a2. stock is 108 bhp i want to look at 200bhp at the most for now. al help appreciated.
EX coupe
well......most Hondas are close in all the same.....the key is, finding the correct fuel/air ratio...and fuel manage...Also, see if you can find out the compression of that engine. Also the rods...how thick are they...durable etc....when boosting...the lower end is the weak point in ANY situation..up to a certian point...you want to concentrate and these areas....I whish i could help you sme more than that..but my Tech exp on that engine is Zero....the best thing to do is, ask around....and search your head off....
1 - 10 of 10 Posts
