91 crx
adjusting trottle cable???sitting about 1,1oo rpm....and when i rev and let off the gas rpm still rise by itself....where is the right placement for the trottle cable???it's a d16y8 from the obd2a ex coupe...
You could probably lube the cable as well. I'm having the same issue sorta. Mine will stick, sometimes at 3k rpm, lol! Imagine with just an open pipe after header!!!
OP did you ever happen to touch the throttle set screw?
If the plate is cracked open any further than it needs to due to a wrong set-screw adjustment, the ecu will be thrown off not seeing an established base idle hence giving incorrect iacv cycles, disproportional idle fuelling, etc.
91 crx
yea one of my stupid buddy adjust it and it started to sit at 2,500rpm so i adjust it agian and now it sits on1,100rpm...
Just a quarter turn of that set screw is already worth a couple hundred rpms or so.
You're literally pushing the plate open.
Do you know the procedure how to set it back to spec?
91 crx
nope i have no clue the precuders...all we did was just turn the two little bolts pulling the cable towards the passenger side...
