1 - 10 of 10 Posts
K
1.Can anyone help me by telling me how to adjust my limiter on my d17a2 engine cause it's coming in at 4500rpm.
2.Can anyone give me the frame dimensions for the 02 civic ex coupe it has been a really bad accident and i need the dimensions to get it repaired. I am all the way in Jamaica so i would really appreciate the help.thanks[/COLOR
limiter...
which one?? RPM, speed?
either require ECU mods.
dimensions... that will be harder to get without what parts u specifically need dimensions for... and larger text dont help =/
the reason your car is limiting at 4500 is there is a serious problem with the electronics somewhere...
if the ecu seems enough problems or deems one big enough it wont allow the engine to go over 4500... and sometimes it will do that with no CEL's and just a giant vacuum leak or bad map sensor...
you cant adjust it on a stock system
pull the codes, they will tell you if ur check engine light is on
98 Civic EX
he's right...for example, it won't rev past 3000RPM, without the right amount of oil pressure in the head...get the and let us know...
K
Thanks for the advice I will check it out.
EX coupe
it looks like you need oil or something is blocking it
1 - 10 of 10 Posts
