1 - 12 of 12 Posts
The gasket set is EXTREMELY important if you are building a motor. I used everyone gasket in the kit. You get valve seals, oil pan, oil pump, head gasket, exhaust mani gasket, im gasket... I used everything I had and I bought a set off ebay for $53 ish. if you're like me, you'll take off your exhaust mani and check things out or replace your im. so save the spares... their good to have.
cool, what brand where they? i DONT WANT no cheap gaskets.... Felpro or OEM for me
Honda
i can tell you right now they are cheap gaskets, because they were only $53 for what sounds to be a head and block gasket kit. You cant buy an entire engine gasket kit from the dealer, nor oriellys or autozone.....you have to buy the head and block seperate.
You will definately need the block gasket kit, im not sure what mods your doing to your head, but i would reccommend at least some fresh stem seals for the valves.....
i got felpro gasket kits for both the head and block.
head kit was about $100 - $110 give or take (cant remember)
block kit was $70 give or take
from the dealer, a head kit is like $170 and a block kit is about $100
i reccommend felpro.....gaskets look like nice quality, the HG was even three layer steel :TU:
1990 Civic Si
im gonna be using OEM Ishino gaskets all the way! I paid $200CAD for both sets, I wouldnt trust anything off ebay. I have heard good things about the felpro stuff as well. maybe ditch that shitty intake gasket and grab a Hondata one, its reusable anyways and you'll gain a couple of HP to boot
Honda
not to thread jack, but would there be a substancial hp increase using a hondata IM gasket in a boosted app over a NA app?
thanks, and im not trying to thread jack, i just need a simple yes or no.
1 - 12 of 12 Posts
