1 - 3 of 3 Posts
94 si hatch
so when i bought this car the guy told me he thought it needed a new compressor anyway i charged my ac with all the freon it could possibly hold and it started working.... of course the freon escaped over the course of 2 weeks... now idk where the leeks is... i used the stuff so u could see it with the UV light and the glasses and could not find it... i also tried this things that can smell the freon... that didnt work so well either... anyone has any idea if it could be the compressor? or maybe one of the lines?? idk please help?
also everytime i drive my car more than 15 minutes it smells like gas... but when its idling it does not smell at all... i checked the lines going to the gas tank but didnt get any luck finding them... you guys think maybe the injectors are leaking?
Could be the evaporator leaking you will not see that till you take the dash apart.
You could be running rich at idle.
92 honda civic lx
try some stop leak.....should get quite a bit more out of the charge
smell gas?....check the lines , connectors on my civic loosened up on the gas filter a while back........if no fuel leaks........get her tuned
easy fellas i'm just a noob
1 - 3 of 3 Posts
