1 - 4 of 4 Posts
-00 civic ex 4dr auto
so i just finished up a factory swap in it, all is well except for the ac compressor, it is loud as fuck. sounds like its scraping/ginding when its not on, once the ac is on it quiets doewn a bit.
wondering what i should swap out, preferably without recharging the system.
also if anyone has a spare knock sensor PM me :D
check the clearance between the pully an the pressure plate it should be 0.020-.006 it sounds to me like its to tight. if so u can pull the pressure plate off and put a shim in it.
it doesnt look too tight if anyhting its to loose the idle pully kinda wiggles when its on
well to loose is a problem as well and they come from the factory with shims in them so maybe there is a chance u need to take one out. but the idler pulley should be looked into as well it should move around.
1 - 4 of 4 Posts
