1 - 20 of 20 Posts
This may be a dumb question with simple answer. Recently i did a head swap from a d16z6 to d16y8. Still got the same block though and my oil pressure switch leaked. When i started lookig into it i also noticed a bolt next to oil filter that seems like it may be leaking. Really dont know what bolt this is possibly need to replace. Can anyone explain to me what bolt this is.
freeze plug. shouldn't be leaking oil
Meat Popsicle
91 CRX Si
There's a washer that can be replaced from what I recall if it is indeed leaking
Discussion Starter · #5 ·
Where would i be able to find this because iv tried searching and cant find any information on this piece.
Is that a Y block?
That would be a 28mm coolant drain plug
90401-PR4-000 WASHER, SEALING (28MM)
Discussion Starter · #8 ·
Is that a Y block?
Its a Z block. The pic i put it is from online but its the same set up. I looked at it and noticed it had ahit of a gap between the plug and the block. The 28mm is to big for it
Discussion Starter · #9 ·
I looked it up and found out its the block coolant drain plug. So no oil should be leaking from there.
If you haven't touched that plug before, it shouldn't really be leaking. The washer under it is quite thick and will not fail very easily. If it's an oil leak you're trying to plug, save your time and money, and leave that bolt well alone.
Z6 blocks have the drain in front of the block, so we are still clueless WTF you are messing with.
don't know why I doubted you, but I went to look at my block to confirm. weird, wonder what op is talking about now. and I still call em freeze plugs lol
Tape-R taper/driver
EC3, ED8, ED9, EE5
I have a Z6, A6, ZC brown top, and DOHC ZC on engine stands around my garage. They all have the coolant drain plug on the front of the block.
They do have a smaller hole in that location for the fan switch, though.
With the VIN tag on the bottom left, I'm betting it's a late model Y-block.
D15 short block perhaps. The ones we have here for the 1.5 and 1.3 liter engines all have their coolant drain plugs on the intake side.
Y Block - rear position
90001-PM3-003 BOLT, DRAIN PLUG (28MM)
Z block - front position
1.5 B7 block - front position
1.6 A6 block - front position
Notice a trend here?
if it dont fit, its the wrong part. Honda used the same drain plug on a ton of their engines
Reactions: slo_eg8
another op drive by. op should post pic of his block with the area hes confused with. op should also post pic of his engine code with a piece of paper nearby that has the day's date/op's screen name
WASHER, SEALING (16MM) 90443-PA5-000
Oil heat exchanger sealing plug. Older Z6's had them drilled from the factory. This would leak coolant not oil thou
Reactions: slo_eg8 and AJAY
1 - 20 of 20 Posts
