1 - 2 of 2 Posts
i was wondering on aem true boost since you can set it at different boost levels. would you be able to set the boost at a lower psi then what the wastegate spring is rated for? and if you were tuneing it would you want to tune it to the highest psi your going to be boosting at or what your going to be daily?? my wastegate spring is 13 and i want to run off the wastegate spring and run at 16 and 20 would i need a differnt spring or would this one be fine??
Havent read much on that controller but the baisc are.
You cant go lower then your spring rate.
Tune for max boost then set ebc for your lowest and max you want to run.
Most of the time you can run 2x spring rate. So 13spring would be 26psi. But remeber depening on how its hook up it might be a little lower due to intercooler pressure drop.
1 - 2 of 2 Posts
