1 - 3 of 3 Posts
I have a question about the map sensor. The Y8 has it on the fuel rail and my 89 SI hatch has it on the firewall, I know I can extend the wires but there are three on the map sensor and two on the y8. has anyone put a y8 manifold on a crx and came across this? How did you get passed it. someone show me the light. :)
The two wire plug on the Y8 fuel rail is the purge valve for the charcoal canister. If you are using the Y8 TB as well, the MAP sensor is located atop of it. If you are using the A6 TB, just use the firewall mounted MAP sensor. Don't forget to plug any extra nipples on the Y8 IM as there are more than the A6.
even better. well the purge valve should not be that inportant then huh. Thanks for the info. I thought I'd be in trouble. :)
1 - 3 of 3 Posts
