1 - 6 of 6 Posts
i love my a6 motor how hard would it be to swap it ina 00 civic coupe and keep it obd2 for emissions?
y8 oil pump and cranmk sensor
y7 dizzy
and i am good?
or way more then that?
no need to swap the oil pump, do the wire around for the crank sensor.
Will need to change engine motor mount.
well ya i know about the mounts what not.
but i can run it one a y7 ecu and should be emissions ok?
depends on where you live. Will need to keep the Y7 intake.
But if you live in Cali or any other Nazi state, won't pass.
i live in CT it kinda simple it has to have a cat on it it cant have a CEL on and it has to pass the obd2 readyness test. dont matter what motor is in it as long as it pass them 3 tests
1 - 6 of 6 Posts
